VIN checks
Jamesyg
Currently Drives:: Megane 3
VIN checks
Postby Jamesyg » Sat May 20, 2017 10:00 am
I am concerned about VIn checks on the Megane 2010. The windscreen VIN and door stickers are ok but there is no engine number plate visible from the front. Can anyone tell me if there are further VIN numbers on the car perhaps stamped ones that would help me ? There is a number on the O/S suspension turret top but it's mostly covered by sealer and doesn't look the same format as a VIN.? I have done the online checks, V5 document dates of issue , MOT and all the other which come up ok but would like to see a "stamped" VIN on the chassis if possible. Looked really hard so if you have any pictures of the locations would be great
Thanks James
Re: VIN checks
Postby Stranger » Sat May 20, 2017 3:23 pm
Jamesyg
Re: VIN checks
Postby Jamesyg » Sun May 21, 2017 9:39 am
Thanks for the Pictures but it seems to be a mix of previous models and Clios's as I had tried this. Best bet so far is its behind/underneath the drivers seat on the floor? Can anyone confirm this that has the same model and the 2010 .?
