Looking at Renault Megane 1.5 DCI Tech Run
Any questions you may have before you buy or receive your car can go in here!!
hardy.1989
Currently Drives:: Peugeot 206
Postby hardy.1989 » Fri Jun 03, 2011 11:53 am
Hi guys,
I am going to look at a Renault Megane 1.5 DCI Tech Run (2008) megane tomorrow. I was really excited and looking forward to seeing the car until somebody told me how many problems they had with there megane (2004 reg). I've been told the electrics play up alot?
What would your advice be all you megane owners?
Sarah
Re: Looking at Renault Megane 1.5 DCI Tech Run
Postby davelowe » Fri Jun 03, 2011 9:43 pm
Listen to the turbo - if it whistles, walk away. Check the colour of the oil, rev the car and observe the exhaust - lots of smoke, walk away.
Test EVERY SINGLE ELECTRONIC ITEM.
These cars tend to have random electrical gremlins, but most are easily sorted. The big killer is infrequent servicing - particularly with the oil. Ask the owner/garage what is in it, and check the service history. If it's had a lot of semi-synthetic oil or the services have been neglected, leave it where it is - unless it costs £50!
hardy.1989
Postby hardy.1989 » Sat Jun 04, 2011 10:12 am
Thanks, will check. hopefully going to see it later today.
Do the electrics play up alot on meganes?
Postby Anthony » Sat Jun 04, 2011 10:25 am
They can be a bit iffy, but usually only the early models (03,04). By 2008 most things have been sorted out.
Oh and also to my knowledge, it is quite normal for a turbo to whistle a little bit. It's when they 'whine' that you have a problem.
Mine whistles and it is pulling fine, no problems at all.
Postby davelowe » Sat Jun 04, 2011 9:34 pm
Anthony wrote:Oh and also to my knowledge, it is quite normal for a turbo to whistle a little bit. It's when they 'whine' that you have a problem.
I agree - I should have put it clearer.
Megy
Currently Drives:: vectra
Postby Megy » Thu Jul 14, 2011 8:37 pm
Hello.
English is not my first language and I really do not understand completely difference between "whistles" and "whines".
Can you please help me understand?
