Possible New Owner
- Currently Drives:: Ford Fiesta
Possible New Owner
I'm thinking of buying a late 2004 Megane II 5 door 1.4 with 46K miles. Is there any particular issues I should look out for? It only has 2.5 months MOT left is this a worry?. What mileage does the timing belt need replaced or is that relavent for this model?
- Gav
Re: Possible New Owner
Laura 1990 wrote:I'm thinking of buying a late 2004 Megane II 5 door 1.4 with 46K miles. Is there any particular issues I should look out for? It only has 2.5 months MOT left is this a worry?. What mileage does the timing belt need replaced or is that relavent for this model?
Usual advice for the timing belt is 60k or 5 years, whichever is soonest - so if a late 2004 then due soon!
I'm not sure on the 1.4, but there will be loads of discussions in the forum, so a search is worth doing.
Some 1.4 engines exhibit a tappet rattle but I don't think this causes any problems. Good for motorway cruising as the power comes in around 3,750rpm so overtaking isn't a problem. This engine doesn't have variable valve timing so you won't need to worry about dephaser pulley and solenoid failure.
make sure you get wanaty as meganes are known to go tits up i have a 1.5dci had 4 injetors new pipes 3 fuel pumps window regulator windscreen washer dont work boot wouldent lock new head light rear bracket on exhaust garage has finerly agreed to take it back only had it 3 months
biggydoug wrote:make sure you get wanaty as meganes are known to go tits up i have a 1.5dci had 4 injetors new pipes 3 fuel pumps window regulator windscreen washer dont work boot wouldent lock new head light rear bracket on exhaust garage has finerly agreed to take it back only had it 3 months
03 model
