wheel bearings
wheel bearings
how's it going lads .I bought A 1.4 MEGANE DYNAMIC in november for my daughter it was a cat d car ..the entire car drives like a bird she's delighted with it, so i hope to get at least 3 years outa this car.(cost £3000) After 5 mths I have replaced the front spring ("daddy i ran into a big hole in the road and now my car is making a funny noise") Replaced a headlight bulb (notice how many Renaults have only one headlight working) ..not easy with big hands in fact gave up and took it to local mechanic who quotes me £150 to change the timing belt ,not bad?..Now there is this strange like rubbing noise coming from the back of the car does any -body think this could be wheel bearings ?
Re: wheel bearings
Welcome to the forum. You could try jacking the rear wheels up and giving them a spin to see if you can identify the source of the noise. It might be the rear pads not coming off all the way when you release the hand brake.
Re: wheel bearings
agreed, jack it up and have a play matey
Re: wheel bearings
thanks for the help,,, went for a test drive and listen, noise is more like a droning sound; jacked up the car spun wheel, left bearing has gone
regards...
