How Low Can I Go on a 1.9dci megane?
Hi All. Not sure if this has been covered on the forums. I recently bought a megane 1.9dci dynamique and want to make some suttle mods.
1. What are the best springs to use?
2. What is the lowest i can drop without causeing problems to the car,.. i dont think 35mm will be enough as i would like the arches to sit just above the wheels (17s)
3. would it help to upgrade the alloys to 18s?
Any suggestions welcome!
I didnt /wouldnt go lower than -45mm..you'd be getting into uneven tyre wear and shock issues ..
If you have the right size tyres on it should look fine.but 18's will always look better.
I used Spax..cheap and a good name...cant ask for anymore than that....and the ride is good too..
Praise the Lowered.......
- BurntCarcus
- Currently Drives:: Renault Megane 1.9 DCi
Re:
lassi777 wrote:What is pneumati suspension?
pneumatic = air system
rather than oil etc in the suspension legs - it uses airbags which can operate to lower car and raise at flick of a switch - good as at car shows can slam it right to the floor and also good for speed bumps as can raise it up so looks like a 4x4
Renault Megane II - 1.9 dCI
Re: How Low Can I Go on a 1.9dci megane?
If you still want a bit of comfort dont cross the clearance of a standard megane RS
Re:
R55VYS wrote:If you want to go lower than 45mm you'll have to get coilovers, and i think the only set cost over £800 and are only -75 at back and -60 at front, alot of money for the sake of an extra 30mm max. although they do look sweet slammed
Mmmmmmm!!
My current car (non Megane) is lowered 50mm on 18" rims and can go up and down most slopes ok, speedbumps and roads I don't know require more concentration and less speed. Any uneven dip in the road would rip my front end off, however I took the splitter off which has given some more clearance, and no problems. Just remember when you're low, don't park so close to raised curbs
id stick to 17's and get coilovers i have lowered mine to much and i am regretting it a bit looks good though!
- Currently Drives:: Megane 1.5 dci black, tinted , powdercoated black alloys :)
Wile I had my 17inch wheels powdercoated I put my megane on 15" wi only 4o tyre wall it scraped on everything could not get on my drive, so don't lower it too much yer looks coos as f**k but not practical
black 3door megane 17" black powder coated renault alloys tints headunit and 12 edge sub....... Wants all smoothing hids lowering sport interia sport frount bumper then I'm sorted:)
lassi777 wrote:Hi All. Not sure if this has been covered on the forums. I recently bought a megane 1.9dci dynamique and want to make some suttle mods.
1) Ebach or koni Coils / springs
2) On coils -80mm on springs - 45/60
3) yea but even 18s can look small in the arches.
Users browsing this forum: Bing [Bot] and 21 guests
