Hi there how easy is it to remove the front bumper on my megane?
Remove front bumper
Re: Remove front bumper
If it's like mine, easy peasy, 5/10 min job, max...
- McLaren
- Currently Drives:: Megane
Nice one thanks for that am changing my head lights is that a easy job as well then.
Yeah that's easy too, 3 bolts if I remember rightly, one on top one to the bottom and one to the outer side,
- McLaren
joeishmather wrote:Yeah that's easy too, 3 bolts if I remember rightly, one on top one to the bottom and one to the outer side,
Nice one thanks for that seen some black ones that i think would look good on my J LOW
Pay close attention to the plastic lugs that are part of the bumper assembly (NOT the black plastic push in things). If you have removed the three under bonnet M10 nuts/torx in the wheel arches and the trim at the top with the black push in clips and it still won't release at the top, inspect the two or more areas at the top. You will have to insert a screwdriver to release them. If you just tug at it you WILL break them off. If this happens, you can put it back, but it won't be 'proper'. Beware the fog light connector (near side) that can only be unplugged with the bumper half off (get an assistant to help).
- McLaren
MIstry_J wrote:https://www.meganesport.net/bumperandintercoolerguide.htm
THIS IS A USEFUL LINK. CHECK IT OUT
Jay,
Thanks for that
- McLaren
Any one know if this lights are easy to fit or do you have to mod?
Thankshttp://cgi.ebay.co.uk/RENAULT-MEGANE-02-08-BLACK-TWIN-ANGEL-EYE-HEADLIGHTS_W0QQitemZ290544015156QQcategoryZ23009QQcmdZViewItemQQ_trksidZp5197.m7QQ_trkparmsZalgo%3DLVI%26itu%3DUCI%26otn%3D5%26po%3DLVI%26ps%3D63%26clkid%3D7991224002964910264
- Currently Drives:: 2007 renault megane (1.5dci dynamique)
McLaren wrote:Any one know if this lights are easy to fit or do you have to mod?
They should fit straight on if they are the correct ones for your car, and should come with all the bits required . you'll need to remove the front bumper though to get the head lights out.
Jay,
