How to retrofit cruise control, step by step..
Re: How to retrofit cruise control, step by step..
Cheers . will be trying this soon .
- Currently Drives:: megane
Very information guide. Thanks.
James
James
I've managed to find genuine cruise control buttons and airbag,
So I'm selling the makeshift buttons including all the resistors and wire, this means only the 2 wires have to be linked up and the other switch fitted as normal, I will also include the surround that's been cut so you don't have to cut yours...
See pics below,
Offers please, needs to go as I want the money to pay for the airbag I got.
Thanks Joe
See pics below,
Thanks Joe
Change tha makeshift control over to the genuine Renault ones, And changed the airbag.. Used the ribbon wire that's already there, it's 7 core so 2 were unused, fairly easy job, just some tricky soldering with the ribbon wire being so small....
Any interest in the control I used previously as it's no longer needed??
Cheers, Joe
Cheers, Joe
- Currently Drives:: Megane 2 1.6 16v Dynamique
joeishmather wrote:Nope you just need to go o someone/ somewhere (generally good auto electrician) with a Renault clip, or buy yourself one...
Where can we get said renault clip from fella ?
Sebring Exhaust,GT valance,-45 H&R springs, 19" Konig alloys
They start at £120ish for a Chinese one off the Internet else you can get Renault or other auto electrician to sort it, would take them 10 min
- Nige
J*sus lol! Your are ambitious lol...fair play for a small fraction of the cost.
Raise my glass to you, regardless of the roughness.
Not so rough anymore tho, bought the airbag compatible with cruise control and the buttons and now it looks like this..
Well please with it!
Just to add bought the steering wheel and buttons for £30 and the airbag for £71 sold my airbag for £68 and the steering wheels still up for sale!
i have been reading the whole of this topic and the other ones on other forums.
i am looking to do this mod asap and feel confident i can do it
wanting to do it as simply as possible and on a german site there is the guide where you use the existing radio controls, so no need to buy another and fit on the other side of the steering wheel.
i am confused though by a couple of things.
on the german guide, he has made a little connector block with new wires and resistors coming out of it (what is this called?!) and how do i make the wires stay in this connector - so i understand that bit and you end up with 2 wires, a blue one and the combination of the resitors as the other.
he simply swaps out the connector block thats already there for the radio for his new one - so i get this too
but then, when connecting the cables under the steering wheel, he uses snap on connectors (brilliant! no soldering) but i cant work out which cable is connected where!
there is the new cabling which has a blue cable and the trio cable, but i cant gather from the pics which is which
link is here - post https://meganeboard.de/viewtopic.php?p=167127#p167127
can anyone help?
would be greatly appreciated, i have followed the guide here but think the german one is a little tider
regards
Sean
can anyone help?
regards
Sean
i have just checked behind my panel before ordeing the parts needed and noticed that i do not have the white ISO plug behind the facia.....
Is this already there if you are able to fit the CC or is it fed through from somewhere
Help please
Help please
Have a good look in there, mine wasn't obvious but if it's not there then you can't do it...
joeishmather wrote:Have a good look in there, mine wasn't obvious but if it's not there then you can't do it...
Oh swizz, ill have another look in the morning. will be gutted if i cant........... can you buy this piece of wiring from Reno then..........
Nope,unfortunatly not...
Just had another good look with no joy. Oh well something's just ain't ment to be huh.
Cheers for all the help though
Users browsing this forum: No registered users and 42 guests
