Daylight Running Lights
- Currently Drives:: megane II 2.0 DYNAMIQUE black
Re: Daylight Running Lights
Where did you wire them to grosseberger and where did you buy them mate ?
- Currently Drives:: 3 door citrus green Megane II
whufc1990 wrote:Where did you wire them to grosseberger and where did you buy them mate ?
i wired them via a switch from the fag lighter, the switch sits behind the trim panel where the diagnostic port is. the live and earth is taken from the fag lighter then the switch live run out to the lights. the lights are earth direct to the chassis behind the lights. i brought them from Vitrual Village on ebay for £7 problem is they have had water ingress and some of the LED's dont work now, i contacted them and they have sent me a new set which i am going to fill with clear silicone to stop the water.
54 1.5DCI Extreme remapped,JVC Head unit, Pioneer front Kenwood Rear Amp & 10" sub
This is mine
- Oliver
I use a little device that controls my normal high beams by a pwm (pulse width modulated) reduced signal, so that they glow with about 70% of the normal intensity. Headlamp flasher fuction is not affected.
It´s not officially permitted in Germany, but tolerated...
https://www.daylightrunning.com/
(machine translation)
https://de.babelfish.yahoo.com/translate ... Cbersetzen
best regards
Oliver
Oliver
