tyre pressure monitors
rickesh
Currently Drives:: 1.9 dci privledge
Postby rickesh » Thu Aug 19, 2010 3:27 pm
hi does anyone know if you can change tyre pressure monitors from one set off alloys to another and roughly how much would this cost and would it be worth the hassle?
thanks
rickesh
Re: tyre pressure monitors
Postby Paddy » Sat Aug 21, 2010 6:45 pm
It will be about 5 pounds a wheel. Make sure they go in the same corners.
If you dont fit them you will get constant message saying 'TYRE PRESSURE SENSOR ERROR' Unless you have them deactivated.
rickesh
Postby rickesh » Wed Aug 25, 2010 12:27 pm
i've got the error message at the moment once the tyres came off it was self explanatory from there onwards.
BlueMeganeII
Currently Drives:: 03 Megane 3 door 2.0 VVT Dynamique - Sunroof, 17" Alloys, Keyless Entry and start
55 Grand Espace Initial, Xenons, Leather, Sunroof, Keyless, Sat Nav, Tyre Pressure sensors, 18" Alloys, Roof spoiler/bars.
Postby BlueMeganeII » Sat Aug 28, 2010 5:04 pm
Wheres the best place to get the sensors?
Postby Paddy » Sat Aug 28, 2010 8:31 pm
You are best to find someone selling a set on ebay.
As each sensor costs £46 new from renault. Then £45 - £60 for them to code them (unless you know someone with clip)
I bought them off a fella that changed his wheel and didnt bother refitting them. (£18 on ebay)
I have a CLIP so i coded them.
So now have fully working monitors for £18 :rock
You will also need to check that your motor has the RF pick up to communicate with them.
BlueMeganeII
Postby BlueMeganeII » Sun Aug 29, 2010 7:59 pm
Hmm - I may be looking for an excuse to head to Northern Ireland very shortly :).
