i'm looking at ordering some new headlights
from what i'v seen so far i could get a set of these:
https://www.alloywheelworld.co.uk/produc ... e-rhd-only
i would need to take the motors out of my standard headlights to put them into the new ones to make sure i can still use the headlight level mover thingy (spologies i'm not sure on the correct name)
is this job a massive faf on?
i'v also seen these:
https://www.amazon.co.uk/RENAULT-MEGANE- ... 3&sr=1-108
i'm not sure if you can transfer the motors over i havent looked into it but i'm not sure which ones i should go for, i thought you guys may be able to offer opinions or maybe someone on here has them or has had them before
if anyone has had them or has them now if you have pictures of them installed please feel free to post them i wouldn't mind seeing what the black ones look like on
thanks
Bobby
Headlights
- Currently Drives:: 2004 Renault Megane 1.5 Dci 80
Re: Headlights
Simple job swapping the lights over, it will all be common sense once you have them off, the hard part will be taking the bumper off without snapping all the fiddly clips
Re: Headlights
can you transfer the little motors that alters the height of the beam?
