seat probles
seat probles
would a set of 225 seats fit in a standerd dynamic ? if not what can i do to make them fit any ideas ?
Re: seat probles
yeah they will fit, just make sure there from a 3dr if yours is a 3dr, etc.
Also if there the recaro bucket seats from the r26's you would need to make sure all the runners and bases are with them
Re: seat probles
wat tools do i need to take seats out and fit others in size bolts etc.
Re: seat probles
I forget what the tool is called, a star drive? just like an allen key but star shaped, not sure what size either, main thing you need to remember is to disconnect your battery, otherwise you'll set your airbags off, and poss end up with some black eyes.
Re: seat probles
i dont think i have airbags on my megane standard seats or do i there only in the leathers arnt they
- Anthony
Re: seat probles
No they all have airbags. You must disconnect the battery and wait about 10 minutes before removing them.
Re: seat probles
30 mins to be sure
Steve
Steve
Re: seat probles
so you mean the airbags in my leather seats will work in the dynamique im putting them into how do i go bout fitting jus leave 4 30 mins again
- Anthony
Re: seat probles
-Unplug battery
-Leave for 30 minutes
-Take old seats out
-Bolt new seats in and connect airbag wiring
-Reconnect battery
-Away you go.
-Take old seats out
-Reconnect battery
-Away you go.
Re: seat probles
thank you lads is the height raise handle the same off standard seats to leathers
- Anthony
Re: seat probles
I would hazard a guess at yes. I think they are the same seat just leather faced.
Re: seat probles
Aren't the air bags coded to the ecu? Trip to steelers on the way?
Steve
Steve
- Currently Drives:: 57 plate, Renault Megane, 1.5dci
Re: seat probles
They were a direct replacement in mine, didn't bother disconnecting the battery it was quite straight forward to swap over.
No warning lights popped up or anything
57 plate, Renault Megane, 1.5dci and only £30 per year road tax!
Re: seat probles
M055Y wrote: didn't bother disconnecting the battery
very stupid thing to have done by the way, dont anyone try and replace there seats without disconnecting the battery first.
Re: seat probles
R55VYS wrote:M055Y wrote: didn't bother disconnecting the battery
it worked out fine for me
