i looking for a desent set of shock absorbers for my 1.6 03 plate megane i have got the springs all i need is the shocks does anyone know were i can get a desent set from for a desent price>????
Thankx pete
SHOCK ABSORBERS needed please help!!!
- Anthony
Re: SHOCK ABSORBERS needed please help!!!
Edit: Wooooooo 200 posts!
ye iv got the springs they are the apex ones n ye im after sme uprated ones that can take the lower a bit betta and not bottom out as much lol
thanx pete
thanx pete
Bite the bullet and spend the money on Ebach coilovers, you wont be disapointed.
- Anthony
Look here:- https://www.europerformance.co.uk/pages/ ... kabsorbers
Or here:- https://www.venommotorsport.com/prod_cat ... del=Megane
You not thought about getting apex ones?
Ideally you should replace the shocks no matter how low you go, as the reduced spring height, wheather it be 25mm or 45mm means that the shock isnt using its optimum movement zone.
