seat problem
preston1234
Currently Drives:: 54 plate 1.4 16v renault megane dynamique
seat problem
Postby preston1234 » Wed Feb 03, 2010 2:23 pm
i recently brought the recaro f1 seats for my 1.4 all fitted fine but just wanting to know how to turn the airbag and service light off any ideas? many thanks
steve-t
Re: seat problem
Postby steve-t » Wed Feb 03, 2010 4:26 pm
think the air bags are coded to the ecu
prob a trip to steelers for reprograming and lightening of wallet
steve
tyler_565
Currently Drives:: RENAULT MEGANE MK2 1.4i 16v sport 3dr blue, apline headunit, 2* JL audio 1000w 12' subs, 2* JL audio 400w speakers, 4* JL audio tweaters, JL audio 1800w amp, poineer 6*9 400w, ipod nano 16gb, 4 12' blue neons, FOX 17' 8 spoke white&silver, PI 40mm lowering springs, k&n 57i induction kit, powerflow backbox&tip, angel eyes headlights, wind deflectors, JJ tints windows, 6 inch tint strip, eyebrows,
cagiva mito 125
foggy rep
Re: seat problem
Postby tyler_565 » Thu Feb 04, 2010 2:18 am
concetor under the seats, grease them up always does the trick for me.
cagiva mito 125
foggy rep
preston1234
Re: seat problem
Postby preston1234 » Fri Feb 05, 2010 7:16 am
What do u mean by "grease them up" thanks
Re: seat problem
Postby davelowe » Fri Feb 05, 2010 3:33 pm
I think he means disconnect the battery negative terminal and wait 20 minutes so you don't set off an airbag by accident (make sure you have the radio code). Then check the connectors and wiring under the seats carefully for any problems. Any connectors can then by cleaned up with wire wool etc to remove corrosion, spray with WD40, reconnect and apply a little Vaseline to protect from further problems. Reconnect the battery, enter the radio code and reset the windows. Let the engine idle on restarting until up to temperature, rev to 2k for a minute or two then go for a mixed speed drive so the ECU relearns your driving habits.
You may need an ELM137 reader and laptop to reset the fault lights (£30 ebay). If they recur, then you may need the airbags recoding by the dealership (use the same kit to list the fault codes).
Re: seat problem
Postby Paddy » Fri Feb 05, 2010 11:31 pm
No their coded... as above trip to the spanner monkeys and leave wallet behind.
