CUSTOM INDUCTION KIT ON A dCi
Posted: Thu Nov 19, 2009 11:29 pm
* Edit post
* Report this post
* Reply with quote
Re: How to take out air box?
Postby Sadret89 on Thu Nov 19, 2009 7:33 pm
- Remove battery
- Unclip ECU connectors
- Remove battery tray / ECU
- Remove airbox-to-throttle body rubber tube
Then, with the battery tray removed, you'll be able to see the airbox's air intake tube that runs on top of the chassis leg. There are three extensions attached to the front end of the intake tube: cold air feed pipe from behind the grille, and two resonator chambers. Now remove all those three.
Next is the fun part if you're into s&m: You must pull the air intake tube free from the airbox. The problem is, there's not enough room for the tube to come forward and not enough room for the airbox to go backward!
I found out it helps to first manipulate the rubber bungs(?) away from around the airbox's locating pegs. This gives maybe a centimetre more clearance for the airbox to go back. Then you must free the clips holding the air pipe to the airbox, then push the airbox back as far as it will go, and at the same time twist the air pipe's front end so that it can be removed. (That's why you needed to remove those three extensions, with them still attached the pipe can't be twisted.)
With the air pipe removed, the airbox lifts right out.
I had to take out the original cold air feed, take the center part and cut it in half just to get that 90 degree bend piece (got a metal piece if anyone wants, could'nt fit it round), and re-installed a 70mm pipercross cold air feed from the bottom of the bumper straight to the filter to give out more turbo noise
* Report this post
* Reply with quote
- Remove battery
