wheels
- Currently Drives:: 2002 renault megane 2.0 16v dynamique
wheels
hi all was wondering what the biggest wheels r i can fit on my megane without any arch work??
- ICEMAN
- Currently Drives:: Renault Megane II 1.5DCi + Lexus RX 300
Re: wheels
22 inch
- IrvinsMegane
- Currently Drives:: Renault Megane 1.6 16v VVT Dynamique,
Re: wheels
That Cant be Right, Can It?????????????
- dalefletcher111
Re: wheels
Given these are 18s:
viewtopic.php?f=13&t=10217
i think theirs def 2 inch gap on each side of the wheel.
does anyone know if 22s would rub under full lock? or is this the biggest size that dont rub?
2004 1.9dci 120 dynamique 3dr
- Currently Drives:: Kia Cee'd 1.6 CRDi
Re: wheels
it depends on the width of the ally, like you can get 19's that are 7.5" wide then again you can also get 19's that are 9" wide
depends on the alloy
07 Kia Cee'd 1.6 CRDi
Remapped
Remapped
- ICEMAN
Re: wheels
I WAS F'IN with you guys!! lol
19 but then you couldnt get anyone in othersie there will be some scrapage - UNLESS you install some serious springs and shocks....either way the ride will be shite!!
ive got 18's on mine 225 40 18 tyres and they are fine.
17" are a better ride all round...
boith the 18" and 17" will require some lowering to gt you that nice look!
Re: wheels
mystik biskit wrote:hi all was wondering what the biggest wheels r i can fit on my megane without any arch work??
Can't say what the absolute maximum is, but a 225/35R19 tyre on an 8½x19" wheel (38mm offset) I can guarantee to fit, based on my own experience.
Just found the ultimate tyre size comparer site!
Here's a comparison of the Megane original tyre/wheel size vs. the 19" setup I have:
205/50R17 + 7x17" offset 49 vs. 225/35R19 + 8½x19" offset 38
I hope that site finally helps people to understand the "holy union" between tyre width, tyre profile, wheel diameter and wheel offset....
2,0 16V 6-speed manual: -
Re: wheels
Theres a few megs with 20's on, ther eall sports tho so you may struggle finding them for a standard one, the ride quality would be terrible to, you'd feel every little tiny bump in the road.
- Currently Drives:: Renault Megane 1.9DCI Limited Edition Sport
Renault Laguna 3LT V6 (Modified/Show Car)
Re: wheels
I replaced my origanal 17's for 18,s and then went a brought a set of 20 inc 100+ Jets in black.
They were 225 / 35 / 20 rubber with a 7.5 X 20 wheel
The car was lowered 40mm on springs
They went on but caught the front arches when turning corners, it became a pain and i wish i had got 19,s but hay ho, I am now in the process of getting the wide arch kit fitted and the arch will be cut away and then it will be lowered again by 30mm, I had to fit the standered springs back on for the last MOT
Re: wheels
Eddie-- wrote:get the arches rolled solves this
A bit difficult rolling a front arch made of plastic innit?
Re: wheels
Eddie-- wrote:TheFinn wrote:Eddie-- wrote:get the arches rolled solves this
yeah i minded that later one
but you could grind a bit off them or mould them around it easy done just need a respray on the wings after though
Cut them away and fit the wide arch kit is the only way forward
Re: wheels
have you tried just removing the arch linings?
Re: wheels
R55VYS wrote:have you tried just removing the arch linings?
What arch linings??
The 20,s are not a problem at the rear its when you turn a corner where the tyre is directly under the front arch, hit a bump and it bounces up and hits the plastic arch, as for the arch linings, they have been worn away by the tyres.
I wouldent recomend 20,s on a megane unles ur prepared to a little arch work, stick with 19,s its less hassel, "I KNOW"
Re: wheels
i reckon that red one must scuff at the front. plus it looks daft.
Re: wheels
and it would fail mot's over here as the wheels protrude out of the arches.
There was a few that had 20's on that didnt look so daft, black 225 from abroad and a silver one with audi looking wheels on, cant find the pictures now tho.
Users browsing this forum: Google [Bot] and 55 guests
