Go right ahead Ulrich!
ulrich100 wrote:....sand properly......
TheFinn wrote:ulrich100 wrote:....sand properly......
N-O-O-O-O-O-O-O-O-O-O!![]()
What ever you do, don't sand your lights!!!![]()
Just wanted to make this absolutely clear so you don't ruin your lights.The backlight tint spray is such that it adheres to plastic without sanding. Just make sure the lense is free of any grease and silicone and you'll be fine.
TheFinn wrote:OK, maybe I stand corrected here.....Was for some reason imagining much ruffer grits (how's 320 for a scratcher?)
1000 to 2000 grit especially wet-sanded shouldn't destroy the lenses, you're both right about that. But I still think that sanding isn't necessary provided you use a good solvent that removes all traces of wax, traffic film and silicone.
TheFinn wrote:I blacked out mine without sanding them first, must have sprayed at least twenty layers everywhere except over the rear/brake light and indicator area where I only put maybe three to four layers. I haven't been able to track down brighter bulbs (27/7W?) yet, so I decided I need to buff down the area over the brake light with some polishing compound to make it a bit lighter. This is how they looked right after having been sprayed. No pics of the buffed down version yet.
So, if afterwards you're going to buff over the tint directly (i.e. there's no clearcoat over it) bear in mind that the buffing will remove some of the tint, meaning the buffed out end result will be a bit lighter than what you started out with. Or much lighter, depending on how keen a buffer you are.
(BTW, should we start a new thread about tinting lights so we don't hijack Cris's original thread?)
