How Low Can I Go on a 1.9dci megane?
lassi777
Postby lassi777 » Thu Jan 31, 2008 9:32 pm
Hi All. Not sure if this has been covered on the forums. I recently bought a megane 1.9dci dynamique and want to make some suttle mods.
1. What are the best springs to use?
2. What is the lowest i can drop without causeing problems to the car,.. i dont think 35mm will be enough as i would like the arches to sit just above the wheels (17s)
3. would it help to upgrade the alloys to 18s?
Any suggestions welcome!
Say..."Renno"
Postby Say..."Renno" » Fri Feb 01, 2008 8:50 am
I didnt /wouldnt go lower than -45mm..you'd be getting into uneven tyre wear and shock issues ..
If you have the right size tyres on it should look fine.but 18's will always look better.
I used Spax..cheap and a good name...cant ask for anymore than that....and the ride is good too.. :cool:
Praise the Lowered.......
Deano16v
Postby Deano16v » Fri Feb 01, 2008 8:22 pm
if you can afford it go for a decent set of coilovers. budget at least 5-600 for a good set. failing that try and get hold of bilstein shocks and eibech springs
R55VYS
Postby R55VYS » Fri Feb 08, 2008 10:51 pm
If you want to go lower than 45mm you'll have to get coilovers, and i think the only set cost over £800 and are only -75 at back and -60 at front, alot of money for the sake of an extra 30mm max. although they do look sweet slammed
Basenji
Currently Drives:: Megane 2 hb
Postby Basenji » Sat Feb 09, 2008 8:19 am
In that case why not consider pneumatic suspension?
Much more practical and the cost ought to be similar.
zdrówko
Meggie slightly customized http://pl.youtube.com/watch?v=aD_K0VbKYGs
Skype: basenjittt
BurntCarcus
Currently Drives:: Grand Scenic 2008 1.9Dci (130)
Postby BurntCarcus » Sat Feb 09, 2008 1:40 pm
Go for 18's and put 225x40's on. It will be ever so slighty smaller diameter so will cause no rub.
lassi777
Postby lassi777 » Wed Feb 27, 2008 9:56 pm
What is pneumati suspension?
Mattj
Currently Drives:: Renault Megane 1.9 DCi
Re:
Postby Mattj » Wed Apr 23, 2008 7:58 pm
lassi777 wrote:What is pneumati suspension?
pneumatic = air system
rather than oil etc in the suspension legs - it uses airbags which can operate to lower car and raise at flick of a switch - good as at car shows can slam it right to the floor and also good for speed bumps as can raise it up so looks like a 4x4
Renault Megane II - 1.9 dCI
Re: How Low Can I Go on a 1.9dci megane?
Postby wanda » Wed Apr 30, 2008 11:05 am
If you still want a bit of comfort dont cross the clearance of a standard megane RS
Xila
Re:
Postby Xila » Thu May 01, 2008 3:02 pm
R55VYS wrote:If you want to go lower than 45mm you'll have to get coilovers, and i think the only set cost over £800 and are only -75 at back and -60 at front, alot of money for the sake of an extra 30mm max. although they do look sweet slammed
Mmmmmmm!!
My current car (non Megane) is lowered 50mm on 18" rims and can go up and down most slopes ok, speedbumps and roads I don't know require more concentration and less speed. Any uneven dip in the road would rip my front end off, however I took the splitter off which has given some more clearance, and no problems. Just remember when you're low, don't park so close to raised curbs ;)
dan27w
Currently Drives:: megane mkII 1.5 dci
Postby dan27w » Thu Jul 08, 2010 11:18 pm
id stick to 17's and get coilovers i have lowered mine to much and i am regretting it a bit looks good though!
D20BTL
Currently Drives:: Megane 1.5 dci black, tinted , powdercoated black alloys :)
Postby D20BTL » Fri Jul 09, 2010 9:30 am
Wile I had my 17inch wheels powdercoated I put my megane on 15" wi only 4o tyre wall it scraped on everything could not get on my drive, so don't lower it too much yer looks coos as f**k but not practical
black 3door megane 17" black powder coated renault alloys tints headunit and 12 edge sub....... Wants all smoothing hids :) lowering sport interia sport frount bumper then I'm sorted:)
Postby Paddy » Sat Jul 10, 2010 7:24 pm
lassi777 wrote:Hi All. Not sure if this has been covered on the forums. I recently bought a megane 1.9dci dynamique and want to make some suttle mods.
1) Ebach or koni Coils / springs
2) On coils -80mm on springs - 45/60
3) yea but even 18s can look small in the arches.
