WHICH BRAKE DISC ARE BETTER
redmeganematt
Currently Drives:: renault magane vvt 1.6.16v
Postby redmeganematt » Sun Jan 24, 2010 3:42 pm
Stupid question time i guess
whats better to have grooved discs or drilled discs.
as i am looking for new brake disc and pads but dont no wots better.
matt
2005 3 door 1.6 vvt in flame red. eibach springs -30mm. 17" nervasport alloys
Re: WHICH BRAKE DISC ARE BETTER
Postby Anthony » Sun Jan 24, 2010 6:03 pm
IMO Grooved.
Drilled discs can develop hairline cracks around the holes which can lead to them failing.
Have a look at Brembo Max.
Any decent brand of fast road pads will give you a significant improvement in brake bite and feel. I have used EBC Greenstuff on the Mini and am currently using Black Diamond Predator pads on the Megane. Both I can recommend.
anth_dci
Postby anth_dci » Sun Jan 24, 2010 6:56 pm
neither, just get flat disks. unless you are using them on track the disks will not get hot enough to warrent groves. never buy drilled because the will crack and become very dangerous
pw981
Postby pw981 » Sun Jan 24, 2010 7:31 pm
I agree with anth_dci as well, I personally think just normal brake discs are fine for normal road use. But if you must, grooved and not drilled - same reasons as above! :cool: If you want an upgrade pad then go for something like EBC greenstuff.
What ever you decide to do though, make sure you're not just upgrading the fronts or rears only, always upgrade both at the same time or none!
There are technical reasons for this, which unfortunately I do not have the expertise to go into - but I have researched it briefly online a while ago for a brief explanation! I'm sure someone else can elaborate! :cool:
2004 Megane II 1.9dCi
Postby Anthony » Sun Jan 24, 2010 7:45 pm
Grooves on discs are really just there to deglaze the pad and keep a 'like new' surface on them. Because of this they go through pads quicker. They also help by moving gases away through the grooves.
redmeganematt
Postby redmeganematt » Mon Jan 25, 2010 4:59 pm
Cheers for the advise guys think ill get a set of groved disc thn with greenstuff pads.
Postby Paddy » Tue Jan 26, 2010 9:39 pm
I have EBC green stuff pads and disks all round and they have made a considerable differance to the stopping distance.
If groved pads dont get hot enough on the roads, you aint driving properly! ;)
Postby Anthony » Tue Jan 26, 2010 9:49 pm
ulrich100 wrote:I have EBC green stuff pads and disks all round and they have made a considerable differance to the stopping distance.
Amen to that.
Users browsing this forum: No registered users and 16 guests
