225 exhaust on a 2.0l vvt dynamique
- Currently Drives:: renault megane mk2 dynmic 2.0l
can anyone help please. I want to fit a 225 blueflame performance exhaust to my 2.0l vvt dynamique, can it be done. I know the rear bumper will need modifying. Thanks
- A13XDT
Re: 225 exhaust on a 2.0l vvt dynamique
You will need to change the rear bumper for a 225/R26 one depending on the year of your car.
The 225 bumper has a visible exit, surrounded by plastic, your car has a hidden exhaust exit.
225 rear bumper
Your bumper
Alex
225 rear bumper
Your bumper
Alex
you could just neatly trim the bottom of the bumper aswell, as the 225 bumper is lower than the std, the exhaust shouldnt be to far away from the bottom of the bumper so you might only need to cut two semi circles out of the bumper, it will probably end up something like a gt rear end, you will need to buy the 225 exhaust mounts, and if its a cat back system your looking at, it wont fit, the bolt pattern on the front of the system is different, although someone may be able to cut a bit off and bodge it on, but your probably better just buying the backbox, and getting someone like powerflow or exhausts uk etc to make you a cat back pipe and fit the BB.
Even if you jsut buy the backbox it will need modifiying to make it fit on, its not just a straight forward swap that you could do in the garage, unless your handy at welding
