Megane Sports Saloon...a bit different...CarPC inside
Cris
Re: Megane Sports Saloon...a bit different...CarPC inside
Postby Cris » Mon Sep 01, 2008 11:11 am
Any comments or suggestions are more than welcomed! :)
Megane II - KW Variant2 Coilovers, RS front, 17" Wolfrace, Custom 2.7" Navi , Custom center 7" Monitor, Custom "iDrive", Custom CarPC DSP, Custom SQ Audio System, etc.
bobsimes
Currently Drives:: megane cc 1.6
Postby bobsimes » Mon Sep 01, 2008 4:46 pm
I now have this mod fitted to my vehicle,
do not attempt this mod unless you are good at fiberglass work and soldering iron work ect as it is not easy and it is easy to damage the instrument panel which would be very costly as each one is coded to the car, i managed it but not using fiberglass as i tried it but got it everywhere, i carefully cut between the instrument dials with a dremel until the gps unit fitted in, i then blanked off the back of the lights with tape so the original stop/service/alarm armed lights do not flash through.
i then rubbed down the removable cover from the gps unit and sprayed the instrument dial area and the gps cover with matching black paint.
i was going to use the starter button to turn the unit on/off but this did not work so i used a small push to make button from maplin and positioned it below the steering wheel.
the gps sensor is located under the clock unit also all cabling goes down to the back of the radio from this point.
i used a 3.5mm plug into the gps unit and fabricated a wire to plug it into the rear of my radio aux connector (update list unit)
cost - 105 for a second hand gps unit
10 - 15 for swithc paint ect
now works fine and looks good!!
Cris
Postby Cris » Mon Sep 01, 2008 7:02 pm
You just have to post a pic of your work! Glad to see I'm not alone anymore...more of these and people will think they're a standard option. ;)
TJM
Postby TJM » Tue Sep 02, 2008 3:23 pm
Nice car! :cool:
Renault Mégane II sport saloon
-1,6 16v manual
-Expression pack
-Noir nacre
-Eibach Pro Kit + GTS Performance shocks
-Alpine
-Impulse
-Alarm
-TAG alloys
-Raid angel eyes
Cris
Postby Cris » Tue Sep 09, 2008 12:12 pm
Thanks TJM! :)
Cris
Postby Cris » Sun Sep 14, 2008 4:29 pm
New pics. RS front and KW Varinat2 coilovers.
Cris
Postby Cris » Thu Sep 25, 2008 7:51 pm
Postby Paddy » Fri Sep 26, 2008 12:24 pm
bobsimes wrote:I now have this mod fitted to my vehicle,
Could you take a picture or two please?
necrophagist
Postby necrophagist » Fri Sep 26, 2008 4:02 pm
Nothing to add other than this is absolutely amazing. Great job
Cris
Postby Cris » Tue Oct 07, 2008 8:41 am
Postby Paddy » Tue Oct 07, 2008 3:22 pm
Cris wrote:ImageImage
That is one nice car! i also have a black saloon, can i ask where u got the after market rear lights from... been looking back cant find any where!
Postby wanda » Wed Oct 08, 2008 1:58 pm
So then knight rider where did you put the rocket launcher and the machine gun :?:
Cris
Postby Cris » Fri Oct 10, 2008 12:55 pm
Ulrich, the taillights are the stock ones. They're just smoked...;)
Wanda... :driving
Postby Paddy » Fri Oct 10, 2008 3:53 pm
Cris wrote:Ulrich, the taillights are the stock ones. They're just smoked...;)
Wanda... :driving
O is that right.... just smoked... very nice! And how would one one go about 'smoking' their tail lights?
Top job my friend ... ill have a few more questions of you dont mind?!
TheFinn
Postby TheFinn » Fri Oct 10, 2008 3:55 pm
ulrich100 wrote:O is that right.... just smoked... very nice! And how would one one go about 'smoking' their tail lights?
Like this.
