Increasing Performance
Charlsburg
Currently Drives:: 2003 Megane 1.9dci 143bhp Dynamique + Comfort Pack
Re: Increasing Performance
Postby Charlsburg » Wed Jul 02, 2008 10:18 am
Hey lol, hmmmm not too sure but i think any mods you do to the engine might invalidate warranty. but the good thing with this box is that you can take it of when ever you need to so its just stock then. ive got the classic and so far im well chuffed with it, better performance and mpg (getting 52mpg now) where as before i was getting 48ish. the premier hall mark has 2 extra features i think, an off on button and a delay on it before the box kicks in, cant quite remember but if you give them a ring theyl answer all ya questions.
3dr '53 Dynamique 1.9 Dci 143bhp with comfort pack
kevcomdude
Currently Drives:: 1.5 Dci
Postby kevcomdude » Thu Aug 28, 2008 10:40 am
I purchased a similar plug and play box from ebay, I will not mention company or names. Initially it was amazing it was pulling all the way through the rev range rather than just between 2-3.5 revs. I tried a 0-60 time with and without the box, and managed to knock 2 seconds off the time with it plugged in. Great......
Until i drove to work this morning.... its started missfireing and the service light came on saying there was a problem with the injectors. I was running it from standard without adjusting the dial on the box.
I will be sending this back and asking for a refund and the company in question so far have allowed me to do this.
You can draw your own conclusions, Im just adding my personal story to the discussion.
Charlsburg
Postby Charlsburg » Fri Aug 29, 2008 12:39 pm
That will be one of your glow plugs if it said check injection, try running the engine a bit so it warms up, then totaly turn everything off then start up again. if the Service light goes off its a dead glow plug. apparently its a common fault with dcis. hope this helps.
