Usually it's just a matter of locating the adjuster rod's ball end in the equivalent "cup" in the headlight, then attaching the adjuster's body to the headlight by pushing in and twisting. It's the (kind of) same sort of bayonet fitting as rear light bulbs have.
I had some Chinese-made headlights on my Twingo, they had a design flaw where the travel of the original adjuster wasn't sufficient, they always pointed too low even if I wound the adjustment screws to the max upward. These AAs for the Megane are designed better in that respect?
My new Angel eyes headlights, now mounted (Phase 1)
Here is my raid angel eyes chrome:
Renault Mégane II sport saloon
-1,6 16v manual
-Expression pack
-Noir nacre
-Eibach Pro Kit + GTS Performance shocks
-Alpine
-Impulse
-Alarm
-TAG alloys
-Raid angel eyes
-1,6 16v manual
-Expression pack
-Noir nacre
-Alpine
-Impulse
-Alarm
-TAG alloys
-Raid angel eyes
- 000KMCGP
- Currently Drives:: Megan Sedan 1.6 16v
Re: My new Angel eyes headlights, now mounted (Phase 1)
they are cool , i have no idea which kit to buy ? , the installer i found is a novice and is scared , got any pix of install or procedeure?
and which kit is best for my sedan megane II , grey - how do i get a blue look ?
thx in adv
thx in adv
- McLaren
- Currently Drives:: Megane
How hard are they to install is it just a case of take old headlights out and swap are to you have to mess about with wires?
Thanks yea my 100post on hear
- Currently Drives:: 2003 Renault megane II 1.5 dCi
They look well dude. seen some on ebay for 150 bar a while back
1.5 dCi megane II, 1600w vibe cbr 12" active evo.
- Currently Drives:: megane 2.0 16v
fitted mine last week but cant get halos to light up on their own work ok with angel eyes
normaly with headlights like these there very simply to fit but may not work exactly how you want e.g halo's on all the time.
this is because the makers have to cover there backside incase you are breaking the law by doing this.
daytime running lights which if you have them on all the time is what they will be classed as must dim down when dipped beam is turned on and which ever side indicater is used that drl must dim while indicater is in use. this normaly means a very expensive control box.
if you want them to work like standard lights they should be great from the box
