lpg conversion
- Currently Drives:: renault megane II 2005
lpg conversion
Hello, i have a megane 1.6 vvt with 150.000 kms on it. I am thinking of converting it to lpg. Will the valve seating be affected by it? Will i compromise the car's reliability with the conversion? Thank you.
- Currently Drives:: - Megane II (2003) 1.6 16V automatic
- VW Caddy Mk.2 1999 1.9 SDI
- Honda Bros 650
- All sorts of 2-wheel leg-propelled machines
Re: lpg conversion
I'd like to know that too. My Meggy is automatic and I was told it can't run LPG. Seems daft but is it true?
Re: lpg conversion
Hi, only the renault 1.2 engine requires a valve saver kit to keep the valve guides lubricated. The 1.6 should be ok. Engine reliability is unaffected with an lpg conversion.
- Honda Bros 650
Re: lpg conversion
ryn079 wrote:Hi, only the renault 1.2 engine requires a valve saver kit to keep the valve guides lubricated. The 1.6 should be ok. Engine reliability is unaffected with an lpg conversion.
Thanks!
Users browsing this forum: Google Adsense [Bot] and 25 guests
