225 discs on a megane 2 1.9
Mud plugger 4x4
Currently Drives:: Megane 2, 3 door 1.9 turbo
Postby Mud plugger 4x4 » Tue Jan 01, 2013 1:33 am
Hey guys
Does anyone know is megane 225 front discs fit straight to a megane 1.9dci 53 plate
Many thanks
Mud plugger
morganjake1544
Re: 225 discs on a megane 2 1.9
Postby morganjake1544 » Tue Jan 01, 2013 6:45 pm
Discs are bigger (312mm vs 280mm) so calipers (also bigger) also required and then maybe the std alloys won't fit? So, no not a straight swap unfortunately.
pfeek114
Currently Drives:: Megane MK2 1.5 DCI
Postby pfeek114 » Tue Jan 01, 2013 8:35 pm
stud pattern would also be different, 225 is 5 stud, dci i suspect is 4 stud, my 1.5 dci is at least so cant confirm the 1.9 or petrol models if anyone else is wondering
Suck, Squeeze, Bang, Blow.........No Smoke, No Poke
Mud plugger 4x4
Postby Mud plugger 4x4 » Tue Jan 01, 2013 11:13 pm
That's a bummer :(
Thanks guys
DK-brun
Currently Drives:: Renault Mégane II Tourer, Dynamique 2,0 16v
Postby DK-brun » Thu Jan 03, 2013 8:23 pm
The RS-models are the only versions with 5 stud. Rest of the Meg's are 4 stud.
Sad but true. Would love to swap for RS-wheels on my Megane..
Kasper Brun
pfeek114
Postby pfeek114 » Fri Jan 04, 2013 11:09 am
you can buy adapter spacers which would change the stud pattern from 4 to 5 stud, but because the rs wheels are already made for the megane, adding spacers would make them extend past the wheel arch making the car an mot failure through too much tread showing
the only other option if you did add spacers would be to buy some thinner wheels to match the 5 stud spacers, but even here you could look into 4 stud wheels of the same design saving you the hassle of getting spacers in the 1st place
its all down to personal choice
