Hi guys,
First time posting here, I have a pre-facelift 2006 megane2. Im after changing the seats to the renaultsport ones from the 225.
Would they be a straight swap? Or would i need the subframes aswell?
Id appreciate Any help or advice that any of you lads can give me.
Thanks.
225 seats.
- Currently Drives:: 2006 1.9 dci 130.
- Currently Drives:: Renault Megane 1.9 dci 130
Re: 225 seats.
Hi
have you found the answer to this yet as im trying to do the same thing.
- ikhan
Re: 225 seats.
Hopefully a straight swap - I'll let you know when I do mine over the weekend
Renault Megane 1.5dCi (106)
Lowered 45mm (Spax)
Lowered 45mm (Spax)
- ikhan
Re: 225 seats.
Yes, straight swap no probs (all connections same on my car) - airbag light is on though, but that's probably cos I drove around with one of the seats disconnected.
Lowered 45mm (Spax)
Lowered 45mm (Spax)
- ikhan
Re: 225 seats.
Airbag light now out - I realised what the problems was the first time a passenger sat on the passenger seat and tried to belt up - the pretensioner had fired on the buckle side (the car the interior came out of was involved in a crash). Replaced the pretensioner and light went straight out....
Lowered 45mm (Spax)
Lowered 45mm (Spax)
- Sadret89
Re: 225 seats.
I've changed the seats and put my pretensioners in but the light wont go out. Checked all the connections, all good.
Any idea?
Any idea?
- ikhan
Re: 225 seats.
I would recheck the connections again, especially on the pre-tensioners.
Your's is a 5-door isn't it? The 2nd pretensioner (nearest the door) may have also fired depending on the severity of the crash the car was involved in (if the interior came from a crashed car). If that is the case, the seat frames are probably twisted / not straight any more as well according to the technical notes.
Did the seats come out from a similar aged 5-door carl? The 3-door version of seats have an anti-submaring airbag fitted to the seat rather than the 2nd pretensioner so that would probably make a difference too.....
Lowered 45mm (Spax)
Lowered 45mm (Spax)
- Sadret89
Re: 225 seats.
the seat rails, pretensioners and seat belt buckles all came from my original seats.
So I would of thought they would be a straight swap.
- ikhan
Re: 225 seats.
I'm not sure then - I only swapped the one faulty pretensioner (and kept my original seat belts) - everything else was as it came with the replacement interior..
Lowered 45mm (Spax)
Lowered 45mm (Spax)
