Hello everyone,
Im looking to change the alloys i have on my car at the moment; however im told i need to make sure any new alloys have the same stud pattern and distance?
Can anybody tell me what i need to know in order to change my alloys to some new ones.
Regards,
Matthew.
Alloy Configuration
- Currently Drives:: 2005 Megane ii hatchback 1.9dci
- Currently Drives:: Renault Megane 1.6 VVT Dynamique Auto
Re: Alloy Configuration
4x100 stud pattern
- Derekosb
- Currently Drives:: Renault Megane CC 1.9 DCi Dynamique
http://i440.photobucket.com/albums/qq12 ... eStrip.jpg - Location: Glasgow
For alloy wheels there are 3 things you need to know to ensure correct fitment.
PCD
Offset
Bore
for an explanation of the above see http://www.alloyguide.com/pcd.php
For the standard Megane II you need
4 x 100 PCD
Offset between 35-45 and a
Bore of 60.1 mm
Size of wheel will dictate the profile of tyre you want to maintain speedometer accuracy (maintain rolling radius).
The Renaultsport Megane's have a 5 stud wheel pattern 5 x 108, Offset 45-60 and 60.1 Bore
I'm afraid stating 4 x 100 is only part of the information you require.
hth
Derek
PCD
Offset
Bore
4 x 100 PCD
Bore of 60.1 mm
hth
Derek
Ok brilliant. Thanks a lot for that.
