CD CHANGER WIRE
Posted: Sun Feb 08, 2009 2:12 pm
by nickbell69
Removed Cd changer in mine and there are 2 connectors on it. Main 1 with all usual wires and on 2nd connector a single blue wire that goes up into dash area i think.
Anyone know what it's for and where it goes to?
Cheers Nick.
Re: CD CHANGER WIRE
Posted: Sun Feb 08, 2009 2:46 pm
by -KJ-
It's for the illumination of the buttons on the changer!
Re: CD CHANGER WIRE
Posted: Sun Feb 08, 2009 4:31 pm
by nickbell69
Cool any idea what it connects to under the dash?
Re: CD CHANGER WIRE
Posted: Sun Feb 08, 2009 6:15 pm
by -KJ-
In my car it's part of the wiringloom to the radio, it comes out of it halfway.
Re: CD CHANGER WIRE
Posted: Mon Feb 09, 2009 9:14 pm
by mws
That single blue wire tells the cd changer to light up when your headlights are on.
It goes into the loom for the radio display in the center of the dash.
I found this out when retro fitting a renault cd changer to my megane.
Took it out of one megane to put into mine couldn't see where this wire went so just cut it off.
Then wired it all up in my megane except for the blue wire, all worked ok but didn't light up with the dash lights.
I've got a haynes manual for the car and had a look at the wiring diagrams in the back worked out that it went into the radio display.
wired it up to the right one and now it lights up with the rest of the dash
Re: CD CHANGER WIRE
Posted: Sat May 09, 2009 10:32 pm
by faffer
mws wrote:That single blue wire tells the cd changer to light up when your headlights are on.
I have just bough a s/h changer with lead for the same purpose.The second socket on mine has three pins which one does this single blue wire connect to?
Re: CD CHANGER WIRE
Posted: Sat May 23, 2009 9:46 am
by nickbell69
This is where blue wire connected on mine on back of radio.Between the red and black. Is that what you meant?
Re: CD CHANGER WIRE
Posted: Sun May 24, 2009 8:29 am
by faffer
nickbell69 wrote:This is where blue wire connected on mine on back of radio.Between the red and black. Is that what you meant?
My radio has this "blue wire" however the indash changer (which fits under the radio) has a second 3pin connector for its button illumination. From the forum I was expecting to find a single connection which I could hook up to the blue wire on back of radio. Since the changer is working fine without the illumination I will probably leave as is.
