Page 1 of 2
Custom Dials
Posted: Sat Feb 07, 2009 10:47 am
by Enagem
Has anyone installed custom dials or changed the colour of the led's? Im interested in getting a white speedo kit or change the red illumination to white. Ive seen these lockwood ones which they sell in white
https://www.lockwoodinternational.co.uk/ ... i2435.html Any idea how I can change the led's behind the speedos?
Re: Custom Dials
Posted: Sat Feb 07, 2009 3:44 pm
by Ray
i agree.. i wouldn't bother changing them but if you really want to.. check
https://www.metal-monkey.co.uk for custom dials. my mate got some for his fiat back in the day..
Re: Custom Dials
Posted: Tue Feb 10, 2009 11:48 pm
by Poddy
I tried to do this myself brfore, and it cant be done unless u want to solder the repalcement LED's on to ur current dash
http://www.meganeownersclub.co.uk/forum/viewtopic.php?f=13&t=9274heres the link to when i tried to do it.
Re: Custom Dials
Posted: Wed Feb 11, 2009 5:15 am
by MrAsia
This was my attempt.
The SMD LEDs are very small and you need a degree of soldering skills to be able to do it.
I would NEVER do it again after finding out how much a dashboard replacement costs if it was buggered up.
Re: Custom Dials
Posted: Thu Feb 12, 2009 9:35 pm
by Paddy
MrAsia wrote:This was my attempt.
I have just found my weekend project... can some tell me how to strip the dash? so i canget busy with my soldering iron...
just as a matter ofinterest if fecked up how much for a new dash?
Re: Custom Dials
Posted: Fri Feb 13, 2009 3:15 am
by MrAsia
just pull the sun shield towards you to get it off. then it's just a screw for the dashboard.
i asked renault and was quoted $1k AUD for a replacement dash
Re: Custom Dials
Posted: Sat Feb 14, 2009 2:34 am
by MrAsia
yeah, dashboards aren't cheap. but well worth it if you are confident with the soldering iron.
Re: Custom Dials
Posted: Sat Feb 14, 2009 11:58 am
by marthill
Is it defo only the sun sheild that has to be pulled of to remove the speedo is there any airbag wires etc to be worried about?
Does the sun sheild just pull off easy or need to be released with small smooth object?
What sort of leds are being used (voltage and size and where did they get purchased from?)
Re: Custom Dials
Posted: Sat Feb 14, 2009 2:25 pm
by MrAsia
the sun visor, just give it a tug towards you, comes right off.
there is a single screw holding the dashboard in place, its located right at the top. the clip for the dashboard at the back is very easy to remove, unclip and pull out.
the dashboard uses SMD LEDs, can't remember which ones it uses since it was a long time ago, but they are tiny.
Re: Custom Dials
Posted: Sat Feb 14, 2009 8:01 pm
by Paddy
ok, so i stripped the dash and saw what LEDs were required. Now the question is what colour to change to? I was thinking about the ice blue through out, including clock display and around fan controls? any thoughts?
Re: Custom Dials
Posted: Sun Feb 15, 2009 3:48 am
by MrAsia
change the LCD to white, a nice contrast. i didn't want to change it all to one colour as it doesn't look nice or classy.
Re: Custom Dials
Posted: Sun Feb 15, 2009 11:08 am
by busternlouie
ulrich100 wrote:ok, so i stripped the dash and saw what LEDs were required. Now the question is what colour to change to? I was thinking about the ice blue through out, including clock display and around fan controls? any thoughts?
Blue dials with red needles, a la VW ?
Re: Custom Dials
Posted: Sun Feb 15, 2009 4:37 pm
by Ray
scirocco has white dials now with red needles!
Re: Custom Dials
Posted: Mon Feb 16, 2009 11:53 am
by marthill
Is it easy to change the clock led colours ? How does that come apart anyone got guides?
Re: Custom Dials
Posted: Mon Feb 16, 2009 4:41 pm
by Paddy
Would these be the bulb type you used?
Ultra Bright Blue 0603 SMD LEDTechnical SpecSource Material: InGaN
Emitting Colour: Blue
Emitting Wavelength (nm): 460-470
Size: 1.2 x 0.8 mm
Intensity (mcd): 80-110
Viewing Angle (deg): 20
Forward Voltage (mA): 3.0-3.6
Forward Current (V): 20-30
