Custom Dials
- Currently Drives:: Skoda Octavia 2002, 1.8t 20v turbo, L&K
Toyota Yaris 2001, 1.3 16v
Custom Dials
Has anyone installed custom dials or changed the colour of the led's? Im interested in getting a white speedo kit or change the red illumination to white. Ive seen these lockwood ones which they sell in white https://www.lockwoodinternational.co.uk/ ... i2435.html
Any idea how I can change the led's behind the speedos?
- Ray
- Site Admin
Re: Custom Dials
i agree.. i wouldn't bother changing them but if you really want to.. check https://www.metal-monkey.co.uk for custom dials. my mate got some for his fiat back in the day..
- Currently Drives:: Kia Cee'd 1.6 CRDi
Re: Custom Dials
I tried to do this myself brfore, and it cant be done unless u want to solder the repalcement LED's on to ur current dash
http://www.meganeownersclub.co.uk/forum/viewtopic.php?f=13&t=9274
heres the link to when i tried to do it.
07 Kia Cee'd 1.6 CRDi
Remapped
Remapped
Re: Custom Dials
This was my attempt.
The SMD LEDs are very small and you need a degree of soldering skills to be able to do it.
I would NEVER do it again after finding out how much a dashboard replacement costs if it was buggered up.
Remapped Mégane 1.6L
Re: Custom Dials
I have just found my weekend project... can some tell me how to strip the dash? so i canget busy with my soldering iron...
just as a matter ofinterest if fecked up how much for a new dash?
Re: Custom Dials
just pull the sun shield towards you to get it off. then it's just a screw for the dashboard.
i asked renault and was quoted $1k AUD for a replacement dash
Re: Custom Dials
yeah, dashboards aren't cheap. but well worth it if you are confident with the soldering iron.
- marthill
- Currently Drives:: Meganne 2 150bhp 5 door
Re: Custom Dials
Is it defo only the sun sheild that has to be pulled of to remove the speedo is there any airbag wires etc to be worried about?
Does the sun sheild just pull off easy or need to be released with small smooth object?
What sort of leds are being used (voltage and size and where did they get purchased from?)
Re: Custom Dials
the sun visor, just give it a tug towards you, comes right off.
there is a single screw holding the dashboard in place, its located right at the top. the clip for the dashboard at the back is very easy to remove, unclip and pull out.
the dashboard uses SMD LEDs, can't remember which ones it uses since it was a long time ago, but they are tiny.
Re: Custom Dials
ok, so i stripped the dash and saw what LEDs were required. Now the question is what colour to change to? I was thinking about the ice blue through out, including clock display and around fan controls? any thoughts?
Re: Custom Dials
change the LCD to white, a nice contrast. i didn't want to change it all to one colour as it doesn't look nice or classy.
- busternlouie
Re: Custom Dials
ulrich100 wrote:ok, so i stripped the dash and saw what LEDs were required. Now the question is what colour to change to? I was thinking about the ice blue through out, including clock display and around fan controls? any thoughts?
Blue dials with red needles, a la VW ?
- Ray
- Site Admin
Re: Custom Dials
scirocco has white dials now with red needles!
- marthill
Re: Custom Dials
Is it easy to change the clock led colours ? How does that come apart anyone got guides?
Re: Custom Dials
Would these be the bulb type you used?
Ultra Bright Blue 0603 SMD LED
Technical Spec
Source Material: InGaN
Emitting Colour: Blue
Emitting Wavelength (nm): 460-470
Size: 1.2 x 0.8 mm
Intensity (mcd): 80-110
Viewing Angle (deg): 20
Forward Voltage (mA): 3.0-3.6
Forward Current (V): 20-30
