Hey, I've just got myself a MeganeRS 175DCI and am loving it!
In my old Fiesta I had a Blaupunkt stereo that I could plug either a USB HDD (80GB) or a SD card. The headunit could handle numerous folders/tracks on the memory card/HDD and was pretty good.
Now that I've got a megane I'm stuck between transfering the Blaupunkt into the megane, or buying a tunepoint.
The questions is though, what capabilities does the Tunepoint have? I know you can plug USB & IPod into it, but how does it handle the USB side of things?
- Does it have a maximum storage (eg you can only plug into something >8GB or upto 40GB etc)
- Does it have a maximum number of folders you can have in the root folder?
- Does it have a maximum number of tracks on the whole drive?
- Does the screen display Folder/Track names or does it just number the folders and tracks 1 - xxx
I've tried using the search function, and tried looking on the internet but cant really find much info in depth on it.
Thanks,
Ben
Tunepoint
Re: Tunepoint
Bmorgan85 wrote:Hey, I've just got myself a MeganeRS 175DCI and am loving it!
Thanks,
Ben
Hi Ben, I've checked the booklet for the Tunepoint, and it has the following info:
There doesn't seem to be a limit to the size of USB device - the only restriction is that it must be an MSC (Mass Storage Class) device i.e. a device that a PC can recognize as external storage without additional software or drivers being required.
The max number of folder layers is 8
Max number of files is 32000
Max number of folders is 32000
It is not compatible with the following: DRM protected files, Non MSC devices, USB hubs, multiple slot USB card readers, multi partition devices.
Hope this helps, Gary
Re: Tunepoint
Thanks for the reply Gary, it does help to have some info on it...although I'm still a little confused...
So does this mean that you could have as many folders as you like on the root of the USB, but only 8 layers, and as long as there isn't a total of more than 32000 folders?
Folder 1
->Folder 1a
-->Folder 1aa
--->Folder 1aaa
---->Folder 1aaaa
----->Folder 1aaaaa
------>Folder 1aaaaaa
------->Folder 1aaaaaa
Folder 2
Folder 200
...etc
So theoretically if I had no subfolders, then I could have 32000folders in the root and it would still play?
I'm confused because someone on rs.co.uk said it could only take a maximum of 6folders in the root with only 100tracks in each?
Cheers,
Ben
garyt wrote:The max number of folder layers is 8
Folder 1
->Folder 1a
-->Folder 1aa
--->Folder 1aaa
---->Folder 1aaaa
----->Folder 1aaaaa
Folder 2
Folder 200
...etc
Cheers,
Ben
