Aftermarket Headunit under Renault headunit.
Posted: Tue Aug 12, 2008 10:47 am
by pXuis
Is it possible to fit a aftermarket headunit under the Renault headunit (where the cd changer goes) ? My reason is that i wana run my subs and 6x9's off the aftermarket, but still keep the Renault radio running the door speakers. Know its weird, but i'm not normal
Thanx.
Pix
Re: Aftermarket Headunit under Renault headunit.
Posted: Tue Aug 12, 2008 11:53 am
by A13XDT
The gap is large enough for a head unit. I did put my sony in for about a day. But there isnt a fascia adaptor that will tidy up the space around the side.
Also, you will have to split the ISO blocks to get sub and back's to work without the front. But you already knew that im guessing.
Alex
Posted: Tue Aug 12, 2008 1:19 pm
by pXuis
yea, was kinda hoping to find a facia, i'm in South Africa, and getting all the needed cables keep steer controls etc. are hard and veary pricy to get. guess i'll stick with the oem deck and get a split system or something. fanx 4 the help
