Radio Problems
Posted: Mon Feb 18, 2008 1:45 pm
Not sure if this is a common problem, but can't find any references to it anywhere.
53 Plate 1.9dCi Dynamique with 'standard fit' radio/cd player + 6 cd multi changer undeneath it.
Problem is with the radio. When i sit in the car and just turn on the radio I can get an ok signal most of the time(can hear Radio 1 without too much interference).
When i start the car the signal is totally lost and all I get is static.
When i'm driving the signal sometimes get's slightly better (less static) but not listen-able.
I've tried checkin the ariel all the way from the roof down to the back of the radio unit and it all seem's ok. I've tried cleaning all the contacts. Tried replacing the ariel plug that goes into the back of the unit.
No luck.
Not sure if it's also relevant, but when i play a cd, sometime it will lose volume - as if I'd turned it down slightly, when i brake.
Any ideas guys as i really begrudge letting Renault have it and charge me an arm and a leg.
No luck.
