DAB in Sunderland/Newcastle area.
Everso
Postby Everso » Thu Feb 22, 2018 2:07 pm
Hi Peeps,
I am getting my Megane 2 on Saturday and would like to put a DAB adapter in there. Issue is that we are in a poor signal area. Has anyone got any advice on installing a DAB aerial suitable for a poor area? Best I guess would be to replace the existing FM aerial and replace it with something DAB compatable. Not even sure if that is possible.
If I can't do that then I guess something on the windscreen but I do not hear good tings about them ... unless someone here knows better.
Looking forward to getting my MEgane on.
Everso.
steve-t
Currently Drives:: Liquid Yellow RS280
Re: DAB in Sunderland/Newcastle area.
Postby steve-t » Thu Feb 22, 2018 3:40 pm
Yes very possible
I replaced mine with a JVC AVX-2 single din cd/dvd head unit the add on DAB tuner and replaced the aerial with a JVC dab aerial.
Everything was picked up excellent. I live just outside Newcastle.
Everything is still in my garage as took it all out when sold the mk2
Steve
Everso
Postby Everso » Thu Feb 22, 2018 4:00 pm
Ah - so there is hope.
So replace the existing aerial with something like this
https://www.ebay.co.uk/itm/Universal-Ro ... Sw8lpZHVuD
if I am reading you right...
From what I read the head lining is held with velcro so it should be quite east to run the cables...
steve-t
Postby steve-t » Thu Feb 22, 2018 9:20 pm
This is the ones I have
https://www.amazon.co.uk/JVC-HAL2-Roof- ... dab+aerial
http://www.dabonwheels.co.uk/JVC_HAL-2_ ... erial.html
http://www.dabonwheels.co.uk/Kinetic_ST ... erial.html
Open the rear hatch, Pull off rubber seal - careful of sealant grease.
Two clips on roof lining to remove.
This will give you hand access carefully reach in to release Velcro.
Think its a 19mm spanner to loosen nut.
Need to run the dab cable to head unit but the am/fm is a fakra connection behind C pillar
Steve
steve-t
Postby steve-t » Thu Feb 22, 2018 9:26 pm
Take a look at this too
viewtopic.php?f=12&t=5673&hilit=jvc+avx+2
Steve
