Hi Guys,
I have just swapped my Double Din head unit from my Honda CR-v to the Meggy 2004...cut away the wee bar plugged the large Black and Large white connectors into an ISO connector, this has left a wee yellow and blue connector, which I assume is for the old 6 CD changer and stork controls...problem is I have no power...with ignition on or off...any ideas....failing that it might be a trip to halfords !!
This unit works fine out of the box in the Honda.
Any help gratefully welcomed.
Dj
Double Din Power issues
- Rally Driver
Re: Double Din Power issues
i recommend buying the correct adapter lead and just hope you have not blown anything
I don't think I have the wrong lead, it is the correct one for the Reg, just doesn't have the Steering wheel controls, many don't.
