Hi guys I've just installed my din2 Chinese head unit, however I can't get the canbus to work with the steering wheel controls, does anybody have a clue how its done ? The instructions don't make sense so can't get it to work
Canbus help needed.
Re: Canbus help needed.
When I installed mine it was plug and play , I did not have to do anything ,I plugged the steering wheel control plug into the can bus adapter that was supplied and it all worked.
Recheck that all the plugs in are in correctly and the see if it works' there should be a set up menu where you will find a steering wheel control set up page ,
On this page you press start, press the icon for the function you require, then the button on your stalk for this function then store on the menu set up page , if this don't work contact your supplier
Cheers I have tried the set up menu but still can seem to get it work, there doesn't seem to be a save function, thanks for advice I've contacted my supplier .
