HELP Remote wire from sub to Standard Head Unit!
willholdsworth
Currently Drives:: 59 plate Megane cc Dynamique s
Postby willholdsworth » Wed Nov 02, 2011 4:06 pm
Ok so Im having an issue finding a wire to use as the REM, Ive found a blue wire, but when I connect it to it, the head unit goes to "Mute"
Im having a real problem getting it to work or to find any wire for the remote with to connect to. You can see in the picture where ive got the blue wire connected to on the left side of the picture .... Your help is appreciated!!!
p/s this is in my 55plate meg 225
Image Owner of a 59 Plate Chipped 1.9dci CC + Inferno Orange Megane Sport 225
mattyc25
Currently Drives:: megane mk2
Re: HELP Remote wire from sub to Standard Head Unit!
Postby mattyc25 » Wed Nov 02, 2011 4:35 pm
Hi Mate,
Remote wire is the blue one
Matt
mattyc25
Postby mattyc25 » Wed Nov 02, 2011 4:36 pm
If it doesnt work on the blue, then its the blue/white wire
Matt
willholdsworth
Postby willholdsworth » Wed Nov 02, 2011 4:49 pm
As I started when I use the blue wire, on the standard head unit is making the head unit go to Mute mode which is strange. Do you know for sure if its the blue and white wire, as you can see from my photo, ive got wires going everywhere and spotting the exact wire without hacking everything to bits is hard, i need specifics if possible?
arran.vigar
Currently Drives:: Megane II 03
Postby arran.vigar » Sun Jan 08, 2012 11:11 pm
sorry i noticed you replied to a post in november havent logged on for a while and didnt send me an email like it usually does. I dont know if you rectified the problem. The blue wire you found must be the telemute wire which is for hands free kits. You know have two options wire into an ignition based feed but this will mean that every time you turn on the ignition with radio or not the sub will come on. or if you get a multimeter and test each wire turning the radio on and off by the power button (NOT BY IGNITION) you will find which one it is.
arran.vigar
Postby arran.vigar » Sun Jan 08, 2012 11:15 pm
Red = Ignition
Yellow = Permantent
Orange = Illumination
Blue = Antenna Remote (if your looking at the wrong harness it is telemute)
Blue/White = Amp Remote
