hello
i have see this navigation for my megane 2 fase 1.
but does works my steering remote with this navigation ?
https://www.xtrons.com/2-DIN-car-dvd/7-F ... TD716.html
singaal is analog this is the manual for the steering remote https://www.xtrons.com/UserFiles/Downloa ... 7752a4.pdf
and i have see this navigation : https://www.fekatel.com/webshop?page=sho ... &Itemid=11
radio/nav megane
- Currently Drives:: megane 2 fase 1
Re: radio/nav megane
Dear Sirs,
I am the owner of https://www.fekatel.com from Belgium.
First I want to apologize for the fact that I speak bad English.
Regarding Xtrons I inform you that the devices are perfect, only I must indicate that the Xtrons radios only have analog steering wheel control.
As for the Megane radio on our website, which has a CANbus which the motion will work well.
Hi
If i had this plugged to my iphone can i skip tracks using the touch screen?? and also can i make calls using it from the touch screen??
cheers
cheers
Fekatel.com wrote:Dear Sirs,
Cauton... Extrons is cheep muck.
I have had one of there more recent double dins and thought it was pish poor... but then you get what you pay for.
Dear Sirs,
My apologize for the late answer.
If you connect your Iphone 3G(s) with this system you can use the IPOD function, including the phone function with the touchscreen.
About the Xtrons, the last time there some bad products come over from China. Xtrons and Eonon currently have either a bad time
I think Paddy also had bad luck.
Nothing to do with luck...
More due to the manufacturing process and quailty control... or the lac of it.
Of course It is of course not comparable with Pioneer or Alpine, but if we look to the Renault Megane system, i can give a guerantee that it's much better than the other systems, some of the components in the systems are used by Alpine.
