My radio did not work when i went to work yesterday.
-7 very cold! Everything else worked ok.
Found out to fix it easily enough though...
I took it out of the dash, by using then ends of a couple of needle files. Unplugged everything from the back, plugged them all back in, put in the code and it is fine again.
Radio stopped working in the cold..
Re: Radio stopped working in the cold..
How long did you leave it unplugged for?
My stereo has done the same thing couldn't cope with -19......
Just unplugged everything from the back then put them back in straight away, put in the code and the radio stations were still saved.
