Just bought a 2007 megane and fixed a aux lead to the back of the head unit.
What I would like to know is where do I route the lead to use my ipod?
Don't really want to put it in the glove box, is there somewhere on the dash I could put it for easy use.
cheers, rich.
Aux Jack lead
- Currently Drives:: Megane 2007
Re: Aux Jack lead
Worked it out myself so thanks, ha ha.
Re: Aux Jack lead
Which aux lead did you get for this? and how did you feed it back through to the dash?
Re: Aux Jack lead
When i put mine in i just drilled a small hole in the back of the tray underneath the headunit. Works great for putting the cable away when your done using it.
Other than that ive heard of others coming up through the centre console under the armrest.
Re: Aux Jack lead
here's where to purchase the cable also.
Its a direct fit to your headunit provided its an Update List.
https://www.celsusice.co.uk/shopdisp_799.php
Hope this helps.
Hope this helps.
- Napster
- Currently Drives:: Megane Sedan 1.5 dCI 2005
Clio III 1.5 dCI 2007 - Location: Constanta, Romania
Re: Aux Jack lead
I made a DIY one. The cable is lead behind th unit and the center console, pulled behind the Debugging connector and led under the cupholders in front, in the space between the console and center tunnel. It's completely hidden when i don't use it and when i connect something it sits in the cupholders
Renault Mégane Sedan II.1 1.5dCi 82CP 2005 || 93000 km
Re: Aux Jack lead
You can get similar cables to that on ebay at a similar price as well.
You can also find the mini ISO > 3.5mm stereo jack on ebay.
Just search for "renault update list aux" - there are plenty available.
