making an rca output - best options
Posted: Thu Oct 14, 2010 10:04 pm
by rbrocky
ok, i need to make an rca output for my amps
ive got a few options i have seen on ebay
here is option 1
https://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
option 2
option 3
https://cgi.ebay.co.uk/Hi-high-level-spe ... 27b56019e2
any other better options welcome :)
if possible i would like to try and keep my speakers
be it tapping into the original speaker lead or adding an addtional socket
thankls alot
BROCKY
Re: making an rca output - best options
Posted: Thu Oct 14, 2010 10:20 pm
by davelowe
Get hold of a dual gang potentiometer of around 10 - 50k Ohm (log) - expect to pay no more than 30p for it (a simple carbon track will do). Wire terminal 3 (as you look at it) to the speaker output, terminal 2 to your RCA socket, and terminal 1 to earth (or the other speaker terminal). The other 'half' of the pot is for the other channel. Adjust the level to suit - ie where you don't have any distortion in the new amp. Even if you wire it backwards swapping 3 and 1, you will just have a volume control that goes 'the wrong way' and in any case, you are only going to use it for calibration - after that leave it alone (hide it somewhere).
Fairly sure that's all that there is in these magic boxes.
