HELP WITH 6 CD CHANGER????
MartyBoy90
Currently Drives:: Renault Megane Dynamique 1.6 VVT (3 Door Black)
Postby MartyBoy90 » Thu Jun 10, 2010 5:02 pm
Alight Guys, Does anyone know how i can get my cd player (not standard one, one from haldfords) to work with the 6 CD CHANGER in the front OR get my sub working with the standard cd player that comes with the car.
thanks ;)
Re: HELP WITH 6 CD CHANGER????
Postby Paddy » Thu Jun 10, 2010 10:16 pm
The only way to get a sub to work with a standard head unit is to use a 'line convertor'.
This however will disable your rear speekers.
And its far from perfect.
As to connecting the halfords multi change to the OEM HU. you would need to post more info.. Ie Standard HU specs (tuner/update) and the model of the changer.
Ill look at the specs and see if connections match.
