CD's STUCK
- Currently Drives:: Renault megane 1.6vvt D Sport Tourer
CD's STUCK
Can anyone help me as i have a cd stuck in my player? what to do?
Re: CD's STUCK
Remove the unit from the car using the proper tool that slides into the two holes at each side then carefully take it to pieces (probably by removing a couple of screws on the casing). See what you can find out from there. You might be able to fix it if you can find out why its stuck. Otherwise the problem might come back and you will end up having to buy another one.
Re: CD's STUCK
mine somtimes gets stuck but only on cdrs it always comes out eventually just kept pressing the eject bottun every now and again and when it comes out do not use that disc again
Re: CD's STUCK
What age is the car...
This happened in my mums Golf... well she put a second CD in when there was one already in it. (should the unit take a second when one is in place??) Anyway VW replace the whole unit.. They said it want worth tampering with so put in a new one..
If its under warenty go badger a renault monkey see what they will do!
- A13XDT
- Currently Drives:: 54 Plate Megane Dci 86 Rush - Platinum Silver
Re: CD's STUCK
Mine once decided it was empty when it had a disc in it. I kept on pressing the eject button, only to get the error noise. I managed to get the disc out by holding a new disc over the sensor, more or less in the unit while pressing eject. This eventually tricked it into thinking there was a disc in there and it came out after 2 mins.
Alex
Alex
- Bumpy macaroon
Re: CD's STUCK
he he just reminded me of my brother-in-law, got a cd stuck in his player, i took it to bits to find a mini cd rattling around in it, then spent 30 mins explaining that yes its a cd and yes it plays in his home system but its too small for a slot loader. the numpty
Bumpy and full of coconuts.
