Shark fin
cactusbob wrote:Ok so with an aftermarket headunit fitted the amp won't be powered?
As long as the aftermarket HU's "remote 12V" output is connected to the wire going to the antenna amp, then it will be powered. The "remote 12V" is the same output that "awakes" e.g. your subwoofer amplifier when you turn your headunit on (that is if you have an external amplifier).
The antenna amplifier's wire at the car's ISO connector is the thin white/green wire IIRC, at least on my '03 model.
Ah, so the wire that would come out of the headunit for say a motorised powered aerial should power the aerial amp.
The reason I ask is that in the Scenic 2 I have (as well a the Meggy). The FM reception got worse after installing an aftermarket headunit.
So the power definately needs to go from the headunit to that wire on the ISO connector?
Re: Shark fin
I think mine may be suffering from corrosion. I have no plans to replace with a shark fin, but would like to know how to disconnect the aerial base in the first place and if some wire wool and connector greese would help, or will I need a new £20 aerial base?
Re: Shark fin
As previous posters had commented the problem with mine was indeed the aerial amplifier, it was heavily corroded. Renault garage wanted £25 for the part and £50 for labour. I bought one from a really helpful guy on eBay who sells various Renault parts, he even included the aerial for £15 inc P&P. After a bit of pulling and twisting and the eventual removal of the side panel of the boot, the part was replaced and the aerial was working again. One word of caution to anyone attempting this is not to damage the roof lining by creasing it.
Recommended for Renault Megane parts look up grant1059685 on eBay.
- ICEMAN
- Currently Drives:: Renault Megane II 1.5DCi + Lexus RX 300
Re: Shark fin
Loafhead wrote:One word of caution to anyone attempting this is not to damage the roof lining by creasing it.
Too late!!
Creased and ripped from the clamps!!
Re: aerial base
ICEMAN wrote:the head cloth is only stuck on by velcrooooo!!!
hi i have got a new aerial base for my 03 megane hatch back and just wanted to know when pulling the headlining down it dosnt set the airbags off cos its got airbags on the roof lining studs appreciate your help thanks Rob.
really!!!
Re: aerial base
blueboi2 wrote:ICEMAN wrote:the head cloth is only stuck on by velcrooooo!!!
really!!!
update i've done the aerial base it took all of 5 mins to do.
