Hi, I hope someone will find this helpful. I was installing speakers on the back doors of my Megane 2 2008 1.5 dci Extreme.
For some reason in this trim version there were no speakers or wiring inside the door panels, so I had to figure it out.
I made a video of the procedure for better explaining: https://youtu.be/B53aUznUkIg
The tricky part was finding the connector with the wiring for the speakers. This connector is placed inside the pillar, between the two doors. The connector has six wires of which two are green and do NOT have pins inside the connector. One of the wires should be marked with red color - meaning it is plus (+).
Cut the two green wires and reconnect long cable that will go inside the door panel and to the speaker holder. The cable should be about one meter long.
At the end of the new cable I added Quick Disconnect Terminal that go into the speakers.
Make sure to test the speakers before assembling.
I hope this is helpful and have fun doing it
Rear door speakers install including wiring
- Stranger
- Site Admin
- Currently Drives:: BMW X1
Re: Rear door speakers install including wiring
Thanks for that. I'm sure it'll be useful to someone
Users browsing this forum: Google [Bot] and 16 guests
