Read this if you needhelp on steering adapters or double din
nik_rowlands3
Currently Drives:: Renault Megane Dynamique
Renault Clio Expression
Postby nik_rowlands3 » Thu Mar 21, 2013 11:04 pm
WHAT STALK:
When buying a stalk adapter for your Megane mk2 there are 2 types depending on the age of your Megane
Right the types are
Tuner 2003 - 2005
https://www.dynamicsounds.co.uk/renault- ... UuQWfogHCQ
Update 2005 -2008
https://www.dynamicsounds.co.uk/renault- ... UuQCPogHCQ
IMPORTANT: Be carefull on the 55 plates this is the cross over year and often has the old car dials but the new stereo loom eg the Update.
If your not sure which your car is it want make sure the Front of the old stereo will tell you in the corner.
STEREO BUYING:
Look to see if the stereo says
Steering Wheel Adapter Read
Or a picture of a steering wheel in the advert
Tip: all modern Pioneer Stereos in the BT range support Steering Wheel Adapters.
Right the Patch lead: this is easy if you buy a pioneer stereo you buy a pioneer patch lead , they normally come with your stalk adapter.
Radio: you will need a radio adapter they are about £1.50 of eBay
Double Din Fitting: when you have your original radio removed , you will need to pull out the little tray below , you will know see a bar going across the middle which separated the radio from the compartment cut this out with a hack saw blade be carefull not to slip and scratch your dash.
Right now you need a cage:
https://www.dynamicsounds.co.uk/renault- ... UuRf_ogHCQ
IMPORTANT: the web page says its for a 2005 -2008 Megane , ignore this it will fit all meganes from 03 to 08 as long as its a mark 2
Once you have finished it will look like this
roganp
Currently Drives:: Kia Carnival babybus, Megane 2hatch
Re: Read this if you needhelp on steering adapters or double
Postby roganp » Mon May 27, 2013 10:25 am
Looking to buy a double din adapter and steering controls for my 2003 Megane II hatch. The fascia kit says specifically not for tuner list on the website. Mine is tunerlist, so figure I need:
https://www.dynamicsounds.co.uk/connects ... aMx-JV-TU4
But which fascia. These have the same model number but pics are different:
https://incarmusic.co.uk/car-fitting-acc ... e-kit.html
https://www.dynamicsounds.co.uk/connects ... aMzx5V-TU4
Can anyone help cos shipping to NZ isn't cheap so would like to get it right first time.
Rogan
