Fluid specification for the Megane II & Scenic II range
FAQ and Tips and tricks relating to various problems.
Ray
Postby Ray » Wed Dec 24, 2008 5:12 pm
Fluid specification for the Megane II & Scenic II range are as follows..
Gearbox oil Capacities for the :
JH3 Gearbox fitted to 1.4 (K4J) & 1.6 (K4M) petrol = 2.8 litres
JR5 Gearbox fitted to 1.5DCi (K9K) = 2.5 Litres
ND0 Gearbox fitted to 1.9DCi (F9Q) & 2.0 (F4R) Petrol = 2.1 Litres
In all gearbox types above the oil is filled through the filler plug that is located on the FRONT of the gearbox casing. The oil is poured in until it overflows from the filler hole..
Do not fill through the Breather pipe located on top of the gearbox casing..
The Gearbox drain plug is located under the Differential on the bottom of the gearbox..
Engine Oil Capacities with an Oil filter change for the:
2.0 Petrol (F4R) = 5.4 Litres
1.9DCi (F9Q) = 4.7 Litres
1.4 (K4J) & 1.6 (K4M) Petrol = 4.85 Litres
1.5DCi (K9K) = 4.6 Litres
