As you can see there is no way of doing it from here
Here is a access cover in the wheel arch you can unscrew
Jack car up with Renaults quality jack
Remove wheel
Thats better. Unscrew cover.
Unscrew another cover.
There she is. Pull the plug off the back of the bulb and push wire clip at the top to release bulb.
Now bulb replaced better check it works before i rebuild the car
Torque down wheel nuts nice and tight with size 10 Reebok
25 mins later, All done
Tools used - Sheet to kneel on (a cushion would be better), torch, locking wheel nut adapter, wheel brace, jack, and new bulb.
Enjoy
