hazard lights
FAQ and Tips and tricks relating to various problems.
Phil and Liz
hazard lights
Postby Phil and Liz » Fri Apr 07, 2017 5:57 pm
my 08 1.5 dci has its hazard flashers permanetly on, been intermitent i think till today, now it wont switch off unless battery is disconnected. I'm thinking corrosion in body control unit, any ideas ? are these coded to the car or will i be able to get one from ebay/ scrappies ?
Dont want to break her only 72k and 11 months mot, good tyres new front discs, timing belt 2 years ago
Phil and Liz Jackson
Lanark
grandadbobby
Re: hazard lights
Postby grandadbobby » Fri Apr 07, 2017 7:26 pm
it could be the actual hazard switch gone faulty.
Have you tried disconnecting it.
Bob.
grandadbobby
Re: hazard lights
Postby grandadbobby » Fri Apr 07, 2017 7:45 pm
According to my book, fuse F7B in engine fuse box feeds hazard and central locking.
Pull it and see if it stops.
Bob.
Phil and Liz
Re: hazard lights
Postby Phil and Liz » Sat Apr 08, 2017 8:56 am
Ok connected battery back up this morning, flashers still going. Tried closing and locking flashers did normal one flash then went back to flashing. Tried holding four way flasher button in for 10 seconds still flashing. Managed to pull radio and heater control panel out, removed and disconnected 4 way switch still flasning. At this poin t tried starting car, battery dead and not enough in it to turn starter over, last night when i took batter charger off it did start.So gonnan have to buy a battery at least before i do anything else.
Lanark
grandadbobby
Re: hazard lights
Postby grandadbobby » Sat Apr 08, 2017 12:06 pm
A good and fully charged battery is essential with modern day electronics, it may even be the trouble all along.
Fingers crossed.
Bob.
Phil and Liz
Re: hazard lights
Postby Phil and Liz » Sat Apr 08, 2017 7:03 pm
New battery bought and fitted this lunchtime, still the same, reconnected hazard switch no change tried locking and unlocking , nothing changes. Left it flashinghoping it might stop, 7 hours later still flsahing and one flat battery.Any suggestions for a cheapo code reader to see if there is any codes.
Lanark
stuartac
Re: hazard lights
Postby stuartac » Sat Apr 08, 2017 8:29 pm
Try disconnecting the alarm siren unit which is behind one of the the side panels in the boot.
Phil and Liz
Re: hazard lights
Postby Phil and Liz » Sat Apr 08, 2017 9:08 pm
will try that in the morning, however the siren hasnt been going off. Did tonight when i locked the car but had the bonnet up and the battery disconnected but on charge. Ended up connecting the battery unlocking the car and disconnectingthe battery, putting it on charge
Lanark
grandadbobby
Re: hazard lights
Postby grandadbobby » Sat Apr 08, 2017 9:26 pm
l wonder about damp or condensation in the body control unit, even a money spider across the connections, l think this is something you could check.
lf the bcu needed repairing, look on ebay for someone as local as you can, l had one done for a Clio once (£30).
Good luck and keep us posted how you fixed it
Bob.
grandadbobby
Re: hazard lights
Postby grandadbobby » Sun Apr 09, 2017 12:03 am
From what l have found, Stuatec is probably right. Disconnect the alarm siren, never mind it don't go off, apparently it's water ingress in it.
Bob.
Phil and Liz
Re: hazard lights
Postby Phil and Liz » Sun Apr 09, 2017 11:13 am
Big thank you to stuartac, located and removed alarm siren, connected battery still flashing but switch was in on position and was able to switch off. All now working and am most gratefull. Maybe the administrators could lokk at posting that in the known issues ? Would have saved me a lot of time and stress, battery was a need to have anyway.
Lanark
Re: hazard lights
Postby Stranger » Sun Apr 09, 2017 3:27 pm
Moved into FAQ / Tips and Tricks
Return to “FAQ / Tips & Tricks”
