number plate lamps
FAQ and Tips and tricks relating to various problems.
Phil and Liz
number plate lamps
Postby Phil and Liz » Sat Feb 22, 2014 8:53 pm
as we all know the factory number plate lamps are a) a water trap b) expensive c) rubbish
to avoid £25 for 2 new lamps and the cost possibly of a wiring harness I have done the following
take the lamp and cut off the connector socket flush with the body, from ebay purchase a 501 bulb holder, cut the wiring on the harness and put a lucar connector on each wire, drill a hole where you cut the socket off at the same dimension as the holder, push the bulb holder into place and push the connectors on.
Result !
cost
£3 approx per bulb holder, 25p per connector and satisfaction of a job well done that was better than the original !
Don't know if anyone has posted this before, if so I apologise for wasting anyone's time
Phil and Liz Jackson
Lanark
Re: number plate lamps
Postby Stranger » Sat Feb 22, 2014 9:26 pm
Great result and thanks for sharing.
Do you mind if I move this to the FAQ tips and tricks forum and lock it for users reference?
Phil and Liz
Postby Phil and Liz » Sun Feb 23, 2014 7:34 am
yeah that would be great as i think this is within most owners ability, no pictures though as did not take before and would only havr afters
Lanark
Postby Stranger » Sun Feb 23, 2014 9:01 am
Cheers :-)
Return to “FAQ / Tips & Tricks”
