Dashboard engine temperature.
The section for all Megane III talk.
kompressorgpl
Currently Drives:: Megane 1.5 Dci
Postby kompressorgpl » Fri Sep 06, 2019 12:14 pm
Hello!
I bought a Megane 3 Dci - 2014. On the dashboard the temperature indication is just 1/4 almost all the time. Start & stop does not work either. It's normal? Shouldn't the temperature be in the middle?
Re: Dashboard engine temperature.
Postby Stranger » Mon Sep 09, 2019 5:13 pm
What distances are you doing? Diesels generally run cooler than petrol and start stop won't begin to work until the engine is hot enough.
kompressorgpl
Postby kompressorgpl » Mon Sep 09, 2019 5:52 pm
Stranger wrote:What distances are you doing? Diesels generally run cooler than petrol and start stop won't begin to work until the engine is hot enough.
Well: from 5km to 40 km. After a day of web search i thing the "problem" is the thermostat. Buy design it opens at 83ºC and the engine normal temp. is 75 ºC.
Return to “Megane III”
